Solved Editing/Disabling Open Graph Meta Tags [SOLVED]
When I set to show only display names (not logins), they work normally with Kunena. But if I open a page source, I can find there a real login as a meta tag (<meta property="og:author").
How can I completely disable generating this?
Thank you.
in the meanwhile, you can comment the line 453 in /components/com_kunena/controller/topic/item/display.php;
ssh wrote: Let's wait for a fix.
Code://$this->setMetaData('og:author', $this->topic->getAuthor()->username, 'property');
Thank you! Partially it works. But I have found one more place in that code, which also displays a name:
see below the information from facebook when using the og:author tag:
sharing = caring
I have already disabled this tag as ssh wrote. But this "author" thing is more complicated than I thought before. At this Kunena official forum I don't see this mistake as I see on my site. IDK why.ruud wrote: Hi, og:author is a non-existing tag and should NOT be used.
