Question Integrating ijoomla Ad Agency
4 years 1 month ago #1 by ilkforum
A few years back there was a How-To on integrating ad agency with kunena. I want to add banners within the forum index between the category displays, as well as every 4 -5 topic replies. I wanted to start here before I jumped to modifying it myself, if there was already an instructional. Thanks.
adagency.ijoomla.com/
Attachment not found
4 years 1 month ago #2 by rich
Replied by rich on topic Integrating ijoomla Ad Agency
I don't know this extension but found this info on their page:
Zones
Show ads on ANY module position available on your template and even on other sites.
So it should work on all Kunena positions.
The relevant positions for you are:
kunena_topictitle
kunena_msg_row_1
kunena_msg_row_2
kunena_msg_row_3 and so on...
kunena_topic_2
kunena_topic_3 and so on...
kunena_section_top_1
kunena_section_2
kunena_section_top_3 and so on...
How you can locate all module positions displayed on your Kunena template: docs.kunena.org/en/faq/module-positions
4 years 6 days ago #3 by ilkforum
Hi, thank you very much for the response. I added another screenshot below. I did find one page position within the auto-generated list which you can see in the screenshot ( kunena_topictitle ), but the others are not, For some reason the module positions are listing correctly. What do you think?
kunena_topictitle
kunena_msg_row_1
kunena_msg_row_2
kunena_topic_2
kunena_section_2
kunena_section_2
4 years 6 days ago #4 by ilkforum
There is an option to embed the zone script wherever on a page, which I've pasted below. If I wanted to drop this into the forum between topics, etc. which .tpl files or similar would I do this at?
<script type="text/javascript" language="javascript" src="https://www.yoursitehere.com/index.php?option=com_adagency&controller=adagencyAds&task=remote_ad&tmpl=component&format=raw&zid=206"></script>
Time to create page: 0.411 seconds
