- Thank you received: 1
Question Email cron jon
I have looked on the forum and github and found some information about this and the fact that kunena does not have a cron based email system which is not good for large sites.
There is a feature proposal at joomla to maybe add a global cron based email system which can give a cetralised system for multiple components but where you can configure email rate etc...
Perhaps the kunena team could lend their support to this feature.
issues.joomla.org/tracker/joomla-cms/19073
thanks
shoulders
sharing = caring
Thanks for pointing this discussion, i will following it and see what's will be done in Joomla! 4.x
Like suggested by mbabker we need to use a libraries to do it : issues.joomla.org/tracker/joomla-cms/19073#event-337607
Joomla 'the platform' should have an inbuilt CRON system and email que system. Wordpress has an inbuilt CRON and it is still using global functions.
This issue was closed far too quickly and now will never be done from what I can see. Things like this is why Joomla is lagging behind Wordpress.
Also this would make Kunena function a lot better on high load sites.
