Kunena 6.2.6 released
Question Going from Kunena 1.7 to Kunana 2.0 with sql database only
If not what's my other choice? Do I have to recreate the old Joomla 1.5 site and try to upgrade it with jUpgrade? I tried that while back but it would always hang and never finish the upgrade.
Thoughts?
What comes to Kunena, you can just copy media/kunena folder and all jos_kunena tables into the new database with new prefix and install the component. After that you need to change all category permissions (or migrate with JUpgrade).
I used jUpgrade Pro and I got all users and other stuff imported to Joomla 2.5.11 version. I then installed Kunena 2.0.4 on that site. I transferred all old jos_kunena tables to the new database and renamed them to newprefix_kunena. I copied media folder and made sure new site has the same kunena plugins enabled as the old site.
At that point I tried it, I see all categories and posts but I get these two messages both on frontend and backend:
Warning: array_intersect() [function.array-intersect]: Argument #2 is not an array in /home/dzikson/public_html/j25/plugins/kunena/joomla/access.php on line 178
Warning: array_intersect() [function.array-intersect]: Argument #2 is not an array in /home/dzikson/public_html/j25/plugins/kunena/joomla/access.php on line 179
This is what line 176-181 look like in access.php
Any ideas what I missed?
Edit:
OK, I guess it has to do with what you said about changing category permissions but I'm not sure what you mean by that. I checked all access levels in Category Manager and they're all set correctly. What am I missing?
Edit 2:
OK, I guess it just means you have to reapply every single one for a good measure because that's what I did and it's gone now.
- Yiannistaos
Edit the file: plugins/kunena/joomla/access.php
Find the Lines: 177-184
Edit the code like the below:
..let me know about the result, please
Thank you.
Hello,Yiannistaos wrote: Hello Guys,
Code:public function getAuthoriseActions(KunenaForumCategory $category, $userid) { $groups = (array) JAccess::getGroupsByUser($userid, true); //$post = array_intersect($groups, $category->params->get('access_post', array(2,6,8))); $post = array_intersect($groups, explode('|',$category->params->get('access_post')), array(2,6,8)); //yiannistaos //$reply = array_intersect($groups, $category->params->get('access_reply', array(2,6,8))); $reply = array_intersect($groups, explode('|',$category->params->get('access_reply')), array(2,6,8)); //yiannistaos return array ('topic.create'=>!empty($post), 'topic.reply'=>!empty($reply), 'topic.post.reply'=>!empty($reply)); }
Thank you.
What that fix ?
