Hello after installation kunena 2.0.4 on Joomla 1.5.25 have an error 500 somthing with Timezone error.
The installation completed succesfull.
But!!!
The links from Menu give error 500
Fatal Error was detected!
Fatal Error: Uncaught exception 'Exception' with message 'DateTime::__construct(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Helsinki' for 'EET/2.0/no DST' instead' in /srv/www/htdocs/costfa0806/voloudakis/administrator/components/com_kunena/libraries/date.php:22 Stack trace: #0 /srv/www/htdocs/costfa0806/voloudakis/administrator/components/com_kunena/libraries/date.php(22): DateTime->__construct('Mon, 25 Feb 201...') #1 /srv/www/htdocs/costfa0806/voloudakis/administrator/components/com_kunena/libraries/date.php(105): KunenaDate->diff('now', true) #2 /srv/www/htdocs/costfa0806/voloudakis/administrator/components/com_kunena/libraries/date.php(153): KunenaDate->toTimeAgo(1361779742) #3 /srv/www/htdocs/costfa0806/voloudakis/components/com_kunena/template/blue_eagle/h in components/com_kunena/libraries/date.php on line 22
The error was detected in the Kunena Component.
