Question 2.0.3 to 2.0.4 upgrade error
11 years 2 months ago #1 by davesage
Like others, I have upgraded from 2.0.3 to 2.0.4 and had some issues. The upgrade progressed completely normally but I have no admin menu and all kunena front-end menu items show 'Component 'com_kunena' does not exist'
tried re-installing, checking permissions etc. etc.
Can't find anything wrong in the upgrade process but the menus just aren't there.
My board works ok on the front-end apart from the missing menu items?
Any help would be appreciated,
Dave
11 years 2 months ago - 11 years 2 months ago #2 by sozzled
G'day, Dave, and welcome to our forum.
If you cannot post your configuration report, because the Kunena component cannot be seen on your administrator panel, can you please give us some information about your website?
In particular, we would need to know what version of Joomla you are using. It may also help to know whether your website meets the minimum technical requirements to run K 2.0.4. Any further information that you can provide will be greatly appreciated and will help us to help you better.
Last edit: 11 years 2 months ago by sozzled.
The following user(s) said Thank You: davesage
11 years 2 months ago #3 by davesage
Thanks for the welcome!
I can get to the report as the control panel link still works, I've copied it below for you.
My site certainly meets the minimum requirements and it was running 2.0.3 happily before the upgrade, I wasn't expecting any major changes in this point release.
Cheers,
Dave
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 4M
Joomla default template details : geoforaging_8 | author: Dave Sage | version: 1.0 | creationdate: 2012-02-16
Third-party components: Jomsocial 2.6.2
Plugins: None
11 years 2 months ago #4 by modernmagic
If you go into your forum menu and reselect the Menu Item Type then they should start working again.
We focus on creating, managing and optimizing Joomla websites so you can focus on your own business
modernmagic.com
11 years 2 months ago #5 by davesage
Thanks for the help, I thought I'd already tried that with no success but I've just tried again and this has indeed fixed the Forum front-end menu items.
Thanks!
How do I fix the administrator menu items, there is no item or sub-items showing in the Component menu? The only way of getting to the control panel is to use the Quick Icon.
Cheers,
Dave
11 years 2 months ago #6 by modernmagic
In my case I reinstalled kunena.
Just a reminder, to always use Akeeba Backup first.
modernmagic.com
11 years 2 months ago #7 by davesage
Tried a re-install over the top and no joy - strange as it all goes through ok just no admin menus created.
Have backups in case but the missing admin menus seem like something that should be easily fixable.
Cheers again,
Dave
11 years 2 months ago #8 by modernmagic
After reinstalling kunena, I had to once again reselect the Menu Item Type for each menu item.
modernmagic.com
11 years 2 months ago #9 by davesage
Sorry, I think I'm missing something, I did that to re-create the FRONT-END menu ok, I mean the ADMIN menu in the BACK-END, there is no menu manager for the back-end, I've looked in sql and there are no references to Kunena in the menu table for the admin menu?
Cheers,
Dave
11 years 2 months ago #10 by modernmagic
Do you have a Kunena Menu in the Menu Manager? This should have been created when Kunena was installed.
see screenshot. I have changed the names of the menu items.
modernmagic.com
Time to create page: 0.548 seconds
