Question K 2.0.4 + J! 1.5.25: problem with new pages
10 years 8 months ago #1 by vachos
hello guys i use last kunena 2 with joomla 1.5 and have 1 problem in 1 thread when you make new post and the post's its all ready 15 so the next page must start there is new page with nothing is empty ! some help please ?
thanks in advance
10 years 8 months ago #2 by vachos
Here is the. Problem
10 years 8 months ago #3 by rich
Go in backend to "Kunena > Forum Tools > Recount Statistics" and let count all statistics. That should help you.
10 years 8 months ago #4 by vachos
Iam allready do that but it don't help
10 years 8 months ago #5 by Jiminimonka
Post your Kunena Configuration Report.
Please read the FAQ.
Only one question per topic.
10 years 8 months ago #6 by vachos
How can I do that ? Thanks for help
10 years 8 months ago #7 by vachos
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 32M
Joomla default template details : rt_populus_j15 | author: rhuk | version: 1.0.0 | creationdate: 11/26/07
Third-party components: UddeIM 2.9
Plugins: JomSocial - My Kunena Forum Menu 2.0.4 | JomSocial - My Kunena Forum Posts 2.0.4 | JomSocial - Kunena Groups 2.0.4
Modules: Kunena Login 2.0.4
10 years 8 months ago #8 by sozzled
1) You have the Joomla - Legacy plugin enabled! This is why you are having problems.
See Legacy mode in the Wiki.
Joomla never supported "legacy mode". Kunena is not tested on J! 1.5.x systems running with the Joomla - Legacy plugin enabled. You need to disable this plugin. Unless and until you remove legacy mode from your J! 1.5 site, this problem will never be resolved.
2) You should also use the Blue Eagle template designed for K 2.0.4, not the one designed for K 1.7.2.
3) You have the following plugins installed: JomSocial - My Kunena Forum Menu 2.0.4, JomSocial - My Kunena Forum Posts 2.0.4, JomSocial - Kunena Groups 2.0.4. You do not have any JomSocial installed. You should uninstall these plugins. You do not need them.
4) You should change your forum integration settings (see recommended settings shown in red below):
10 years 8 months ago #9 by vachos
Thanks for help .
I make all the changes but nothing help the problem still there ! The problem begin when the site change server ! Maybe it's something else ?
10 years 8 months ago #10 by sozzled
If you have made all the changes, please post your configuration report again so that we can see what changes you have made. Thank you.
Time to create page: 0.614 seconds
