Kunena 6.2.6 released
Merged How do I change the "default view" of the forum from Recent Topics to Index?
Thanks in advance for any help or advice that anyone can give me.
- 9themestore
- Premium Member
The Kunena default supported direct to Index page or Recent topic page. To answer your question you do any following steps.
Step 1: Login to your back-end.
Step 2: Go to the forum menu in the back-end.
Step 3: Look the right side. In the Menu item choose the "Index".
Step 4: Save and back to front-end and refresh.
Please see the following image.
Regards!
Go to backend - Menu - Kunena Menu
Open Forum item
change to index at "Default Menu Item"
I have [strike]two[/strike] questions regarding setting up the forums and getting them to work for us.
1) I have a question regarding the breadcrumbs and the Forum Home. I noticed that on our test site if you click either breadcrumbs (kunenas or joomla's) it takes us to the Recent Topics instead of the forums Index page. I notice that 'index' is not applied to the bredcrumbs (neither Joomlas nor Kunenas) url.
I am sure I missed something. Can you let me know how to fix this? I know it is possible as it is done here as I would like.
[strike]2) Also, I notice that I cannot get the menu item to work correctly. I would like to have the forum menu item to display it as 'active'. (hover and focus work fine).
[/strike]
triadmain.com/forum/index
Thank you very much! it is greatly appreciated!
Sarrene'
This topic explains how to change the default view (the forum "home") from "Recent Topics" to a category Index view.
I have removed your second question. We prefer that people ask questions relating to a single subject. If you have a question on a different subject, please use a separate topic for those other questions. As general background, you should read Kunena Menu issues in the Wiki.
