Kunena 6.2.6 released
The information given in this category is intended to guide users who want to use various third-party products with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of other Joomla extensions.
Solved Xmap - Kunena Plugin problems
Update a plug-in. Load the version for kunena 3*.
I don't see uddeim or any other PM system here; you can write me to contactoplaystationline-gmail.com and I will give you the credentials.
To ensure it's you, edit your previous post and say that you have written me, please.
Thank you!
iseca wrote: Would you want to see it and do some tries?
No.
I am sorry.
The plug-in is provided ' "as is" ', and I do not provide support.
It was only if it could help you to adapt the plugin to this version, or to see that the problem is mine and don't do nothing.
Regards.
- stumpy_dan
iseca wrote: Hi again!
Now I have updated to 3.0.2 from 2.x, but for me, if Kunena menu is not in first position in component parameters, it doesn't show the forum topics and replies in XML map (In "normal web" map, it does).
Thank you!!
I have the same problem. it does nto show in xml map but does show in normal web map!!.
I am not sure what is meant by "if Kunena menu is not in first position in component parameters" how do you do that?
Thank you!!
Hi Stumpy,
If you go to Components - Xmap and edit your map, at right, you see the Menus you have to be shown in Xmap. Drag & Drop the menus to change the ordering and put the Kunena menu in first position.
Hope this helps,
Best regards!
<EDIT> Apologies, I had forgotten I had already edited an earlier version of this plugin five years ago. I added the improvments, and here it is,but note my version only works if there are not forum subcategories and there are menu itmes for each caegory. However, it also improves on the original version by not duplicating forum categories if they exist.
