The information given in this category is intended to guide users who want to use various third-party products with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of other Joomla extensions.
Solved Xmap - Kunena Plugin problems
Jommla version: 2.5.8
Kunena version: 2.0.4
Xmap version: 2.3.2
Xml sitemap: www.kalipoker-fr.com/index.php?option=co...&tmpl=component&id=1
1. First bug appears in xmap menu settings. I have 3 menus checked: "Main Menu", "Kunena Menu" and "Footer Menu" but only links from "Main Menu" appears in the XML sitemap. The only way to get "Kunena Menu" links visible in XML sitemap is dragging "Kunena Menu" on top of the "Main Menu", being first on the list.
2. All XML links from "Kunena Menu" includes "index" and redirectig to a "/list.html" page.
For example:
- how it looks in XML: " www.kalipoker-fr.com/forum/index/poker-en-ligne.html "
- it redirects at: " www.kalipoker-fr.com/forum/poker-en-ligne/list.html "
- how it should looks like: " www.kalipoker-fr.com/forum/poker-en-ligne.html "
Thank in advance for help.
- havocwreaker
- Junior Member
- Thank you received: 1
havocwreaker is right the xmap plugin is outdated and hasn't been updated for Kunena 2.0
gonzo wrote: First bug appears in xmap menu settings. I have 3 menus checked: "Main Menu", "Kunena Menu" and "Footer Menu" but only links from "Main Menu" appears in the XML sitemap. The only way to get "Kunena Menu" links visible in XML sitemap is dragging "Kunena Menu" on top of the "Main Menu", being first on the list.
Modification of plug-in XMAP for kunena 2.0.4 . It is free. Test, please. These problems are fixed.
If you create a new menu for Kunena and a module for it, Xmap lists the links fine, but the Kunena menu is much more dificult to have a good display result, so this is inviable.
Well, my questions is that; I have no module for K menu, is this correct?
Thanks!
iseca wrote: Hello, I have exactly the same problem but I have discovered that it's related to that Kunena hasn't got a module menu item for it like was in Joomla 1.5, at least in my web; I'm right?
No, this is not true.
Kunena-xmap-plugin does not work in kunena 2.* and kunena 3.*.
I can not promise anything ... but maybe I can help you in your trouble.
Our modifications kunena-xmap-plugin work in kunena 2.0, but do not work in kunena 3. *.
Patience ... Give us a little time, please. If we can do it - I will publish here the announcement of this joyous event.
I'm using Kunena 2.0.4
Regards.
iseca wrote: ...but I have tried uninstalling Xmap Kunena plugin, deleting folder /plugins/xmap/com_kunena and copying text from your file com_kunena.php to original one...
No, it not is my recommendations on installation of a plug-in.
Try to establish an official plug-in and to replace an original file on modified. It also should work.
