Question Kunena emoticons dont work in jomsocial activity stream
13 years 7 months ago - 13 years 7 months ago #1 by spindy
Hello.
Kunena emoticons dont work in jomsocial activity stream.
The emoticon url is: com_kunena/template/default/images/emoticons/
And it should be: com_kunena/template/default/images/emoticons/blush-grey.png
Last edit: 13 years 7 months ago by spindy.
13 years 7 months ago #2 by Cerberus
kunena version ?
joomla version ?
jomsocial version ?
what template are you using for joomla and kunena??
13 years 7 months ago #3 by spindy
Kunena: 1.6 RC2
Joomla: 1.5.20
Jonsocial :1.8.8
Template: anion
13 years 7 months ago #4 by spindy
I did found the problem:
If you change the original emoticons ASCII then the emoticons donw work on jomsocial :)
13 years 6 months ago #5 by beegii
I have this problem too. New smiles doesn't show on jomsocial activity stream. help me
Kunena: 1.6
Joomla: 1.5.20
Jonsocial :1.6.2
13 years 6 months ago #6 by fxstein
sounds like you have custom smilies?
make sure that for every smilie there are two files in the directory: e.g. mysmilie.png and mysmilie-grey.png
For the activity stream the grey version are being used.
13 years 6 months ago #7 by beegii
Yes I installed custom smiles. Yes I put two files in the directory: e.g. mysmilie.png and mysmilie-grey.png. But it doesn't show any smiles on Jomsocial activity stream :(
13 years 4 months ago #8 by havocwreaker
Is there an answer for this. I have uploaded custom smilies in both PNG and GIF. The ONLY smilies that work are the default set. Even though all my custom smilies have a "-grey" version uploaded, they do not appear. I would not bother with fixing it, but IE displays a broken link placeholder. This looks unprofessional on my site.
Is there a way to just disable smilies on the activity stream?
Thanks for any help.
13 years 4 months ago #9 by xillibit
Do you checked the urls or emoticons ? And the permissions too ?
13 years 4 months ago #10 by havocwreaker
Hopefully I can get this figured out before my biz trip tomorrow.
Here are my stats:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 2M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 1.8.10) | UddeIm: Disabled or not installed
I checked the permissions and all the uploaded emoticons both PNG and GIF are set to 0644. Also, the URL is showing up as:
mythrottle.net/components/com_kunena/tem...lt/images/emoticons/
I put all of the emoticons in the default folder.
Thank you and please help ASAP. ;)
Time to create page: 0.603 seconds
