- Thank you received: 5
Question AUP integration not work
Also polls are not shown!
Kunena Team has done in backend "Report Configuration Settings" option which help people here find your problem, you don't tell anything.darksoul wrote: I have latest AUP and i enabled rules and kunena configs.. But points are not visible in user info and no points are assigned.
First of all you have to enable AUP rules for Kunena in AUP and assing points there. You also have to enable in Kunena settings "Enabled Points in profile" and "Enabled Rules for Points" on integration settings (set to "Yes")
Then Kunena configuration is setting what you have point to AUP if you want to show points in message view for users, you have to change "Profiles and User List" to AUP or in other case points not show there.
So... just my opinion, there is little bug and that is, there is not way to show points if want use Kunena "Profiles and User List".
I think K Team fix this now when I reported it in here...
Now you have to use AUP "Profiles and User List" if you want to show points in message view.
I prefer to see CB profile, do you know how to hack?
Another question is that..
*** removed by moderator ***
Is this matter now resolved?
Because i asked for any possibility to show user points also when Profile and user list is CB and not AUP, as i done in k.1.5 hacking the code.
On activity integration, just select AUP, not CB. That would send notifications to AUP and show points from it. You can still keep using CB for everything else -- I don't think that activity integration is much used in CB, at least not yet.
And answer to your second post:
If you need a code edits, they should take place after the kunena.com set the position of a stable version ... before that I do not ship any "hack" of information and also I think I no have to...
I've update to K 1.6 RC 2 and AUP still don't work (I can't give point to user and their points are not updated)..
I also realise that in the "integration tab', there's no more AUP box at the bottom part which in K1.6 RC1 do have 'Enable points in profile' & 'Enable rules for points'. However, in kunena profile, there is point shown.
See atachment from Mortti for reference
