- Thank you received: 24
Question K1.6b and CB1.2.3 gender field issue
I have problem with the gender icon beneath the avatar on the forum. In most cases it says undefined even thou the users have selected gender which is showing properly on their cb profiles.
1. The cb_gender field is named "Пол"
2. In the cb forum integration plugin i have selected "Пол" as gender field
3. On my profile page the gender shows properly (Пол: Машко means gender: male)
4. But on the forum the icon says "undefined"
Any idea what might be the problem?
Tried to put kunena_v1.6.0-RC3_b3539, a problem same.
Still in kunena_v1.6.0-RC3_b3539, the profile from kunena is used.
To profile СB 1.2.3 it is not switched.
Kunens shows
Gender (with the icon)
unknown
Does this come from CB - or where does it get this information -
THANKS
-- Russ T.
( a common issue with templates eh? )
I just noticed it does the same thing on this board (at the time of this posting)
- If you hover the mouse on the icon - It says Unknown (at least on my profile)
- I looked on someone else - and it said Male. - this kinda takes away the browser probability - and leads back to the question - where does this come from - some profiles show it - some do not - I am using Alpha points - this is not "complete" in this profile - but I do not want my users to need to complete 2 seperate profiles - so could there be some confusion about where the information is pulled from?
Where is this information coming from ?
THANKS!
-- Russ T.
We've encountered these problems before and we've fixed them. Please see [Solved] Male and Female icons
P.S. Check the language definitions in cb_gender field values - there must be _UE_MALE and _UE_FEMALE !important
Good luck
Altai Mountains - is a fairy tale!
only1russ wrote: I am using Alpha points - this is not "complete" in this profile - but I do not want my users to need to complete 2 seperate profiles - so could there be some confusion about where the information is pulled from?
-- Russ T.
Try to look here: Gender no-photo thumbnails support
Good luck
