- Thank you received: 1
Solved Male and Female Icons
I am... Kunena 2.0.4 with CB 1.9 on Joomla 1.5.26.
If you have done all of these things and this problem is not resolved they you should contact Joomlapolis (basically because it's their product). I expect that, one day, I will experiment with CB 1.2.2 but I don't have any urgent plans to do this just yet. If you discover that there is a defect with CB 1.2.2 with the integration to Kunena, that confirmed by Joomlapolis, would you please provide an update in this topic?
Thank you so much for your help
As far as your specific issues are concerned, I see (from your installation) that CB 1.2.2 is slightly different to what I'm familiar with. I eagerly await any information you are able to obtain in relation to this new version and provide here for the benefit of Kunena uses.
Noted with thanks!juuk: After looking at your website, I notice that you have a lot of additional CB plugins (most of which I have no familiarity with), some of which may be unnecessary and some of which may be affecting your ability to run full native-mode Joomla 1.5. It's not that Joomla "legacy mode" is not supported, it's that J! 1.0 (and, by extension, anything developed for J! 1.0) is not supported and has not been supported for the past nine months. It is strategically wise, therefore, to remove any legacy components from your website, in any event, or to convert J! 1.0 software to J! 1.5.
The issue at hand is solved. See Joomlapolis solution.I eagerly await any information you are able to obtain in relation to this new version and provide here for the benefit of Kunena uses.
NOTE: Before I did what the team Joomlapolis suggested, I reverted to CB 1.2.1, and the corresponding icons appeared. Now I'm back on CB 1.2.2!
Thanks, Sozzled for your invaluable assistance
Altai Mountains - is a fairy tale!
