Kunena 6.2.6 released
Solved Male and Female Icons
First of all, I haven't yet installed CB 1.2.2 and so I don't know what changes have been made, but this guide is based on my knowledge of CB 1.2.1 and so you may have to adapt it as necessary:
- Using the CB Field Manager, create a new field named Gender (CB will store this as cb_gender)
- Create the field as type "Drop Down (Single Select)". You will need to assign two named values: one will be Male, the other will be Female
- Assign this new field to a CB profile tab
- Modify a CB user profile (go to the tab that you assigned earlier) and click the appropriate radio button to select and assign a gender to the user)
It's possible that I may have omitted a step. I've just checked my own websites (where I have implemented the solution) and that's all that I can see that you need to do. Please let us know if this answered your query.
I've no problem with birthdate. In Forum Integration, the birthday field points to CB's date of birth. That integrated perfectly. In forums, birthdate shown is from CB.I have just tested quickly now on K1.5.9, when i set profile and avatar integration with CB, the data are get from Kunena and not from CB, when i change the birthdate, it always show the kunena birthdate. I haven't investigated more, but i need to fix that asap.
Do you have the same issue ?
I am... Kunena 2.0.4 with CB 1.9 on Joomla 1.5.26.
Thus far, I've done steps 1 & 2.First of all, I haven't yet installed CB 1.2.2 and so I don't know what changes have been made, but this guide is based on my knowledge of CB 1.2.1 and so you may have to adapt it as necessary:
CB and Kunena have enough "smarts" to use your custom-defined Gender field and the two values you've assigned in the cbsimpleboardtab plugin (as long as you've published that plugin).
Step 3 is not in a profile tab but in profile item. Will that make a difference?
Also done step 4.
Gender icon still didn't appear .
You think it has to do with CB 1.2.2?
juuk wrote:
This is something that you should take up with the folks at Joomlapolis .You think it has to do with CB 1.2.2?
So everything works now? :dry:Hi Sozzled. Thanks for the clarification. Field is assigned to a CB profile tab.
Whoops! I forgot to mention... No gender icon still. I need to step out. Perhaps when I'm back in about 3-4 hours, if you're around, I can give you my site's backend access, and you can take a look-see?juuk wrote:
There is one other possibility that you may need to consider. Go to Components » Community Builder » Plugin Management. Locate and edit the Forum integration item (cbsimpleboardtab). See the following image:
(Again, the information and instructions contained herein are based on my knowledge of CB 1.2.1)
Please ensure that you have selected Kunena as the forum component. The item (highlighted in yellow) is located at the top right of the image. This is important ... it is also not the default!
By default, the sidebar mode - this is how you associate CB fields with Kunena - is normally shown (as I've highlighted it in yellow) as "Basic (default kunena)".
Please confirm if your settings are as I've shown above. Although this may not resolve your situation, I want to know what you currently have.
Parameters
Forum component: Kunena from www.kunena.com
Sidebar: Display Setting
Display setting: Basic (default kunena)
Forum Status: Display Settings
Display forum statistics: In User Profile
- Change to Beginner (field selection).
- Select your custom-built gender field for the Kunena gender (see my earlier message #42315 for the title of your field)
