Question Using Kunena signature and subscriptions with Jomsocial profile.
I think Kunena and Jomsocial should at this late date of their respective existence in the Joomla world both had to reach the high level of maturity and instead waiting for other side to finish the job, mutually came up with the solution for this obvious flaw in design.
Even here at kunena site, forum show my gender as "unknown" although i did set mine gender in Jomsocial profile.
Well, you and me, as an site administrators, developers, Joomla enthusiast or whatever... we know how to change this, but try to explain that to regular site user who, in most of the cases dont even have a clue what Joomla! is, not to mention Kunena or Jomsocial.
However,there was a guy which made his own modified version of Kunena 1.5 which handled this (and most of others) Kunena <-> Jomsocial profile issues, but his hacks on 1.5 unfortunately didnt found their place in K1.6
vvolf69 wrote:
johnnydement wrote: Yes, we have the intention to do so, undortunatelly is a 2 ways work, we've pushed integratin as far as we could, now is for azrul to make jomsocial fields be able to write/read in kunena signature field... we could do the other way around, but is impossible for us, as there's no fixed field for this... I mean, js can make a field be stored in kunena signature field, but kunena can't usa a field from js to store the info, as it doesn't exist yet! ;( is not same as avatar, we're able to pick it, as the field exist in database from the start...
Dunno if I made myself clear
this is total bullshit...
each profile field in jomsocial is identified by a unique id and you can get it´s content by using this id. so simply make an option to use a field id of jomsocial instead of the original kunena signature field and you are done.
now you can make a custom field in your jomsocial profile for the signature and add its id to kunena. all you need is an input field in the integration dialogue in the backend. has to be done once and everything is fine... it is the same as picking an avatr. just saying.
i did this myself for kunena 1.5.8 and it worked without any problem.
This sounds perfect...!
Have you done this for Kunena 1.6 as well - and would you share how you did it?
Right now it is not possible for users to navigate from profile Kunena profile to JS profile directly.
There needs to be a proper connect or integration between the two, otherwise users will get confused why they have two profiles.
Community Builder managed to integrate it just fine!
