Question Posts ordering set in kunena admin panel
You don't need hack, the changes are already applied in the files in the archive, just put these files in your FTP and replace the older files.
Don't forget to add this in your administrator/components/com_kunena/language/kunena.yourlanguage.php :
For Kunena 1.5.7, you need to use this :
"Parse error: syntax error, unexpected T_STRING in /home2/onesevsi/public_html/upthewestend/administrator/components/com_kunena/language/kunena.english.php on line 35"
Which is strange because line 35 appears to be "define('_KUNENA_JS_ACTIVITYSTREAM_CREATE_MSG1', 'created a new topic');" which I haven't changed.
Any ideas?
Below is a snippet showing everything from the code I added to the offending line 35. I really appreciate your help.
//Hack to reverse order of posts by default see www.kunena.com/forum/114-hacks/20886-pos...it=10&start=10#34344
DEFINE('_COM_A_POSTORDER', 'Define the posts order');
DEFINE('_COM_A_POSTORDER_DESC', 'Define the posts order in two modes : ascending or descending.')
// 1.5.7
- julianjordan
Thanks for your help
Julian
- fbuonarota
is it possible to have the same hacks for Kunena 1.5.9 version? Please
It is most important for me!
Thanks in advance!!!
