Kunena 6.2.6 released
Question Posts ordering set in kunena admin panel
14 years 9 months ago - 14 years 9 months ago #1 by xillibit
I have made a little hack for change directly the post ordering in the kunena config panel, this works only on Kunena 1.5.3. But this need to be adapted if you use an another template that default_ex.
You need to add this, in your administrator/components/com_kunena/language/kunena.yourlanguage.php :
DEFINE('_COM_A_POSTORDER', 'Define the posts order'); DEFINE('_COM_A_POSTORDER_DESC', 'Define the posts order in two modes : ascending or descending.');
If you don't use the template default_ex, you need just to change this at line 169 :
$ordering = ($fbConfig->default_sort == 'desc' ? 'desc' : 'asc'); // Just to make sure only valid options make it
by this :
$ordering = $fbConfig->default_sort;
Attachment Hack_posts_ordering.zip not found
Last edit: 14 years 9 months ago by xillibit.
14 years 9 months ago #2 by alakentu
Hello xillibit
Great little hack, but it does not work, at least I do not work, does not change the order of the hearing of the messages.
Just assume that if I choose to view messages in "asc" should see the first message in a message created and if I choose to see the messages in "desc" set up to the last message and that message is not so original.
Please could you tell me if you need something more than play the files: admin.kunena.php, admin.kunena.html.php, kunena.language.php and view.php?
Thanks in advance for your answers!
Greetings.
KS!
NO hacer Spam | NO esbribas todo en mayúsculas | Sigue las reglas
14 years 9 months ago - 14 years 9 months ago #3 by xillibit
I don't know why but my modifications didn't worked, now I have fixed this.
File Attachment:
File Name: hack_posts...g_k1.zip
File Size:49 KB
14 years 9 months ago - 14 years 9 months ago #4 by alakentu
@Xillibit.
Ok, The try and tell you that it works my brother!
EDIT: Perfect brother, great job! Thank you very much.
Greetings.
KS!
Last edit: 14 years 9 months ago by alakentu.
14 years 9 months ago #5 by xillibit
Version for kunena 1.5.4 :
Attachment hack_posts_ordering_K1.zip not found
14 years 9 months ago - 14 years 9 months ago #6 by lavsteph
my proposed amendment for an integrate in all languages. ;)
In admin.kunena.php
replace
$sorting[] = JHTML::_('select.option', 'asc', 'Ascending'); $sorting[] = JHTML::_('select.option', 'desc', 'Descending');
with
$sorting[] = JHTML::_('select.option', 'asc', _USER_ORDER_DESC); $sorting[] = JHTML::_('select.option', 'desc', _USER_ORDER_ASC);
Manager French translation
Last edit: 14 years 9 months ago by lavsteph.
14 years 9 months ago #7 by xillibit
Thanks lavsteph for this modification, i have it in the archive below. Don't forget to add this, in your administrator/components/com_kunena/language/kunena.yourlanguage.php :
DEFINE('_COM_A_POSTORDER', 'Define the posts order'); DEFINE('_COM_A_POSTORDER_DESC', 'Define the posts order in two modes : ascending or descending.'); DEFINE('_USER_ORDER_DESC', 'Descending'); DEFINE('_USER_ORDER_ASC', 'Ascending');
Attachment hack_posts_ordering_K1-20090719.zip not found
14 years 9 months ago #8 by lavsteph
the translation already exists in the kunena.english.php
line 1331-1532
//New 0.9 to 1.0 DEFINE('_USER_ORDER', 'Preferred Message Ordering'); DEFINE('_USER_ORDER_DESC', 'Last post first'); DEFINE('_USER_ORDER_ASC', 'First post first');
14 years 8 months ago #9 by sneadm
I'm using 1.5.4 w/CB 1.2.1. I've set Kunena to use the CB Profile. CB defines a field 'forumorder' which the user may set. You may also set the default to '0'(asc) or '1' (desc). This then populates the 'odering' field in fb_users which is used by the kuena_config_class::DoUserOverrides to override the default setting in the class.
I don't know if the native Kunena profile edit allows the user to change this but the CB profile does.
So, different users can have different sorts without the need for the hack.
Hope that helps clarify.
14 years 4 months ago #10 by Roo
Hi there. I'm pretty desperate to get my threads ordered with the oldest at the top but I'm very much an out-of-the-box man. I am rather terrified about hacking.
However, I am determined so....
I have downloaded hack_posts_ordering_K1-20090719.zip but I have no idea what to do with it.
Could some kind person please offer an idiot-proof step-by-step instruction on what I need to do. I would be most grateful.
I am using Kunena 1.5.7 (and, for what it's worth, Community Builder and CB SuperActivity)
Time to create page: 0.501 seconds
