- Thank you received: 566
Question New users need moderator approval for x first messages
During that time user gets this message when he writes a new message: "Your message has been successfully posted. It will be reviewed by a moderator before it will be published on the forum."
Also all posts made by anonymous users needs approval.
-- cut --
Edit default/post.php:
Find (around line 223):
Add this just after that line:
Now modify $minposts to have your preferred value.
That's it!
EDIT: added hold for anonymous users.
- woonydanny
- Elite Member
- Thank you received: 21
I will definately be implementing this very soon. This is something ive been wanting for ages.
thankyou!!!
(would be great down the track to have this as a backend config option)
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile
- FlashDeveloper
That is correct: the file post.php resides in the folder ../components/com_kunena/template/default/ however this has nothing to do with the default template which actually doesn't even exist with new installations of K 1.5.8 on later.I am trying this approach for my Kunena Forum, but there is no post.php file in the default_ex folder, only in the default folder. When I try to switch templates from defualt_ex to default, I have no option for just "default". I imagine if I did, I could make those edits work.
This is a peculiarity of the design of Fireboard that has stayed with Kunena 1.5 (the behaviour changes from K 1.6). There is no need to even try to change templates. Make the changes to post.php; whatever you change there will apply to whatever template you are using.
Excuse my english...
Can this hack apply to K1.5.9 ??
Igor!
yes, you can apply this hack on K1.5.9, the lines number could be different.
There are no guarantees that anything written in the this category will work or may continue to work in later releases of Kunena. Further, you would probably be wasting your time modifying K 1.5.9 because K 1.5.10 has already been released (although it's imperfect) and K 1.5.11 will be released very soon. But, even more importantly, just as K 1.5 made considerable changes to the way that K 1.0 was built, the next generation K 1.6 will invalidate many of the coding structures and conventions used in K 1.5.
Although the ideas used in this topic are still relevant to those perhaps looking for a solution, the implementation of them is outdated.
The solution for 1.5.9:
in /components/com_kunena/template/default/post.php
around line number 443 I have this code:
ok...
replace with:
This solution work fine in 1.5.9.
...$kuser->posts < 1... set the numeber of messages.
This solution is not perfect for robot post, I have set $kuser->karma < 1
In this mode I assign karma to user that can post directly.
Thanks for support Matias.
Bye
Riboni Igor
