- Thank you received: 21
The information given in this category is intended to guide users who want to use AlphaUserPoints with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of AlphaUserPoints.
Important Kunena AUP plugin not working with Jomsocial
- woonydanny
- Topic Author
- Elite Member
everything seems to work ok, except the jomsocial activity stream is not updating with kunena activities!
i have worked out that in the Kunena configuration if i publish both plugins "Kunena - AlphaUserPoints Integration" and "Kunena - JomSocial Integration" it doesnt work.
If i unpublish the AUP plugin and just leave the Kunena jomsocial plugin it works.
I need the AUP published though, because if i unpublish the AUP plugin it does not then give points to kunena activities in AUP!! which is the crux of my AUP usage.
Please help
please can someone help me out! thanks
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile
- woonydanny
- Topic Author
- Elite Member
how can i have AUP and jomsocial both working with kunena? i would like to publish both the Kunena Jomsocial integration plugin and also the Kunena Alphauserpoints integration plugin
1. with JS plugin published the js activity stream works but aup points activity does not work.
2. with aup plugin published with js plugin the aup points activity works, but the js activity stream does not update with kunena activities (eg userA left a thank you, user B posted a topic etc)
how can i get it working? please
I don't know if we can necessarily help you with questions about how to make kunena work with JomSocial - my understanding (and our responsibility) is restricted to how to make basic parts of JomSocial work within Kunena - but, perhaps, someone in the community knows something about this (or maybe the JomSocial team may know more)? I don't personally have any knowledge about the JomSocial Activity Stream (which is not a product of the Kunena team) but, perhaps, the guys who built the interface know more.woonydanny wrote: ... with aup plugin published with js plugin the aup points activity works, but the js activity stream does not update with kunena activities
Not much help, I know, but I suggest you also pursue your line of investigation with the JomSocial team. The answer, however, may lie in what versions of software products you have installed. I don't know what versions of products you're running without searching around for (hopefully) your up-to-date Kunena configuration report.
- woonydanny
- Topic Author
- Elite Member
- woonydanny
- Topic Author
- Elite Member
Jomsocial support palmed me of to AUP support. AUP suggested to reorder the kunena plugins. So I have tried changing the kunena plugin ordering and have found these results:
When the AUP plugin is ordered above the jomsocial plugin, then AUP works as it should. The AUP points are displayed under each users name in the kunena forum and it generates points for each kunena activity.
When the kunena AUP plugin is ordered below the kunena jomsocial plugin, then AUP does not show AUP points in kunena forum and AUP does not generate points for each kunena activity. Jomsocial does generate the kunena activities in the jomsocial activity stream.
So as i need AUP to generate points and show each users points in their kunena area for each of their posts I have had to leave the kunena AUP plugin higher ordered than the kunena jomsocial plugin. However this means that no kunena activities are generated in the jomsocial stream still, which i need to happen as well.
Does this help with figuring out a solution to having both AUP and Jomsocial work correctly together?
many thanks
- woonydanny
- Topic Author
- Elite Member
But Jomsocial have said the issue i am having is Kunena activities into JomSocial stream, which is action from Kunena side. So they are saying kunena need to look into the issue to resolve.
So it seems like it is an issue with the kunena integration plugins which kunena maintain. There is obviously a conflict with using both the jomsocial and AUP kunena integration plugins at the same time.
Can a Kunena dev please investigate. thanks
- Shaun Downend
I have been speaking to one of the Tapatalk devs, and he says that he has spoken to the Kunena team, who believe the problem is on their end. They said they would look into it when they get the chance (low priority).
I am patiently waiting for a fix.
I'm following this thread with high interest because I'm also a user of Jomsocial and AUP - and most likely - a future user of Kunena.
Getting AlphaUserPoints for posts etc to work is critical for me - as well as sending new posts to the stream of course.
If there is a conflict I really hope we can find a solution somehow
I just realized we have different versions of Joomla and kunena and probably jomsocial. for clarification I'm going to put my system specs and suggest everyone else do the same.
- Jomsocial 3.0.5
- Joomla 3.1.5
- Kunena 3.0.2
- AUP 1.9.0
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 360 seconds | Max execution memory: 256M | Max file upload: 24M
ID Name Menutype Link Path 836 Bugs mainmenu view=category&catid=34 bugs-registered 399 Forum mainmenu view=home&defaultmenu=856 kforum 1276 Signature mainmenu view=user&layout=edit group-menu/signature 133 Forum kunenamenu view=home&defaultmenu=135 forum 134 Index kunenamenu view=category&layout=list forum/index 142 Search kunenamenu view=search forum/search 141 Help kunenamenu view=misc forum/help 140 Rules kunenamenu view=misc forum/rules6 139 Profile kunenamenu view=user forum/profile 138 My Topics kunenamenu view=topics&layout=user&mode=default forum/mylatest 137 No Replies kunenamenu view=topics&layout=default&mode=noreplies forum/noreplies 136 New Topic kunenamenu view=topic&layout=create forum/newtopic 135 Recent Topics kunenamenu view=topics&layout=default&mode=replies forum/recent 1443 Bugs public-menu view=category&catid=34 bugs-public 1444 Forum public-menu view=home&defaultmenu=491 kforum-public 1543 TW mainmenu view=category&catid=12 tw
Joomla default template details : JowGradient | author: Troy T. Hall | version: 1.2 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.2 | creationdate: 2013-08-18
Kunena config settings: board_offline 0 enablerss 1 threads_per_page 10 messages_per_page 5 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 disemoticons 0 template blue_eagle showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 rtewidth 610 rteheight 440 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 0 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 50 maxsig 300 regonly 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatarupload 1 allowavatargallery 0 avatarquality 80 avatarsize 1024 imageheight 800 imagewidth 1280 imagesize 450 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2,mp3 filesize 2000 showranking 1 rankimages 1 userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 0 userlist_posts 1 userlist_karma 0 userlist_email 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 0 showstats 0 showwhoisonline 0 showgenstats 1 showpopuserstats 1 popusercount 10 showpopsubjectstats 1 popsubjectcount 10 usernamechange 0 showspoilertag 1 showvideotag 1 showebaytag 0 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 0 ebaylanguagecode en-us sessiontimeout 1800 highlightcode 1 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 0 rss_cache 900 defaultpage recent default_sort asc sef 1 showimgforguest 1 showfileforguest 1 pollnboptions 12 pollallowvoteone 1 pollenabled 1 poppollscount 10 showpoppollstats 1 polltimebtvotes 00:01:00 pollnbvotesbyuser 1 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 imagetypes jpg,jpeg,gif,png,bmp checkmimetypes 1 imagemimetypes image/bmp,image/jpeg,image/jpg,image/gif,image/png,audio/mpeg imagequality 50 thumbheight 80 thumbwidth 80 hideuserprofileinfo put_empty boxghostmessage 0 userdeletetmessage 1 latestcategory_in 1 topicicons 1 debug 0 catsautosubscribed 0 showbannedreason 1 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 10 mod_see_deleted 0 bbcode_img_secure image listcat_show_moderators 1 lightbox 1 show_list_time 720 show_session_type 0 show_session_starttime 0 userlist_allowed 1 userlist_count_users 2 enable_threaded_layouts 0 category_subscriptions topic topic_subscriptions every pubprofile 0 thankyou_max 10 email_recipient_count 0 email_recipient_privacy bcc captcha_post_limit 0 keywords 0 userkeywords 0 image_upload registered file_upload registered topic_layout flat time_to_create_page 0 show_imgfiles_manage_profile 1 hold_newusers_posts 0 hold_guest_posts 0 attachment_limit 8 pickup_category 0 article_display intro send_emails 1 fallback_english 1 cache 1 cache_time 120 iptracking 1 rss_feedburner_url autolink 1 access_component 0 userlist_usertype 0 sefutf8 1 enablepdf 1 jmambot 1 annmodid 10,493,248,272 changename 0 userlist_username 1 rules_infb 1 help_infb 1 onlineusers 1 | Joomla! detailed language files installed:Warning: Spoiler!Kunena - AlphaUserPoints Enabled: activity=1 avatar=0 profile=0 activity_points_limit=0
Kunena - UddeIM Disabled
Joomla! languages installed: en-GB English (United Kingdom) es-ES Spanish (español)
Third-party components: AlphaUserPoints 1.9.0 | Jomsocial 3.0.5
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1 | Kunena Search 3.0.1
