Question Installation problems CLOSED
12 years 2 months ago - 12 years 1 month ago #1 by wsidt
Hi, can anyone help?
I recently installed kunena in a localhost, no problem. Then when I try and install on a different live website I keep getting this error message:
Table 'easysimplewebsitesc_677372_db2.truejos_truejos_kunena_announcement' doesn't exist SQL=SHOW COLUMNS FROM `Truejos_truejos_kunena_announcement`
Nicki
Last edit: 12 years 1 month ago by wsidt. Reason: Solved
12 years 2 months ago #2 by sozzled
Replied by sozzled on topic Re: Installation problems
I suggest that you read K 1.6 and K 1.7 Installation and Upgrade .
Does your site meet the minimum technical requirements to run Kunena? What kind of database engine are you using?
12 years 2 months ago #3 by wsidt
Replied by wsidt on topic Re: Installation problems
I definitely have all the up to date technical requirements and I installed it sucessfully in a localhost site.
Really don't know what to do, any help would be appreciated.
12 years 2 months ago #4 by Jiminimonka
Post your configuration report, un-edited, that may help people find out what the issue is.
Please read the FAQ.
Only one question per topic.
12 years 2 months ago #5 by wsidt
sorry, where do I find this?
12 years 2 months ago - 12 years 2 months ago #6 by wsidt
Have found it now:
Last edit: 12 years 2 months ago by GoremanX.
12 years 2 months ago #7 by Jiminimonka
Delete that information, and then go in your Kunena Configuration and look for the Report Configuration Settings part and paste that information instead of your configuratio.php contents - bad security move there.
12 years 2 months ago - 12 years 2 months ago #8 by GoremanX
Replied by GoremanX on topic Re: Installation problems
Never, ever, ever post the contents of your PHP info publicly. That's very bad security practice. I've edited your post so it's not publicly visible anymore, but you may want to consider editing it to remove that info completely. Please read this page to find out how to get your Kunena configuration report .
www.friendlyphotozone.com
12 years 2 months ago #9 by wsidt
Thank you. I realised what I had done afterwards. Please can you tell me where the report config file is located?
12 years 2 months ago #10 by GoremanX
The following user(s) said Thank You: wsidt
Time to create page: 0.551 seconds
