Question Remove the forum breadcrumbs and top forum controls
I tried also this command, but it blow of the bottem and upper part . I'm going to spend more time in this problem - but patience will also get disbursed
However, if you are really set on making these changes and you accept the risks in doing so you can fiddle about with the file ../components/com_kunena/template/default/threads/latestx.php.
Great thank you for this incredible support/effort
- colinwill78
(what i wanted, but i'm not sure it's what you wanted)
i used the following code at the bottom of my joomla template.
worked for me. easy and no need to update it (unless i change my template)
the first code did the welcome box and the second one did the klist-actions.
Try it out and let me know.
#Kunena table.kprofilebox {
display:none;
#Kunena table.klist-actions {
display:none;
I signed up here just to tell you.
my forum is at www.paddocktalk.com.au/forum if you want to see it, but it still looks sh!t at the moment. still working at the basics.
