Question J! 1.6 + K 1.6 Upgrade error: unable to write entry
- tomholdstock
If I found myself stuck in any situation I would go back to what I knew to try to escape from that situation.tomholdstock wrote: I'm stuck!
If I were in this situation I would drop my attempts to get "unstuck" with J! 1.6 and I would go back to J! 1.5 and I would remain in that comfort zone until we've worked through the J! 1.6 issues properly. I'm not saying that J! 1.6 is not usable and I'm not saying that K 1.6 is not usable with J! 1.6. I am, however, saying that K 1.6.3 is not 100% usable with J! 1.6 in a production environment. See K 1.6 Technical Requirements .
- tomholdstock
The K 1.6 Technical Requirements article states:
If you want to experiment then, by all means, experiment. If you want reliability, support, less stress/worry/anxiety and a broad platform of software that you can select to use in your webcraft then, at this particular time, Joomla 1.5 is probably a better option. However, this situation will change and what I have written is only my opinion. The decision, to persevere or not with J! 1.6, is entirely yours to make. I am only trying to help you but it depends how much time and energy you have to keep travelling along this rather rocky road.Users may want to experiment with K 1.6 and Joomla 1.6. K 1.6.2 provides some capability to work with Joomla 1.6 and this capability will be extended in future releases. There are issues with installing or using K 1.6.x in Joomla 1.6 at this time. Some of these issues are show-stoppers if users are considering Joomla 1.6 to run their production websites. Many of these issues will be fixed in future versions of Kunena and Joomla. At this time uses are encourage to report issues with Joomla 1.6 as test cases but support may not necessarily be available to answer issues. Until otherwise advised, please use the K 1.6 test reports category to report issues that you are having with K 1.6 and J! 1.6. Until accepted by the Joomla Extensions Directory as a native Joomla 1.6 extension, K 1.6 is not a Joomla 1.6 native extension.
It is not necessary to have Joomla 1.6 in order to install Kunena 1.6. The version number is purely coincidental.
www.friendlyphotozone.com
I have the same problem and haven't been able to ascertain what the problem is caused by
