Merged [Merged topic] How do I restore my Kunena menu?
- PaRaDiSiAk
- Junior Member
- NO LONGER USED - DELETE THIS ACCOUNT PLEASE
I think I'll try perseverance and patience... But before I think that i'm going to take 1000mg Paracetamol for the headache caused by this menu to my poor brain...
Have a good night / nice day !
1. Check in Joomla Menu Manager -> Main Menu(Menu Principal). Does there exist menu with name "Forum"? This one should be deleted! Purged from Trash. And after that you can click button "Create Menu" in Kunena Configuration
2. If first dont help, as error say, have you enabled debug in Joomla and Kunena to see what errors show? Also look to Apache Error Log file if there exist some error.
If you find something report here.
Thank you.
- PaRaDiSiAk
- Junior Member
Debug :
Profil d'information
Application afterLoad: 0.002 seconds, 0.33 MB
Application afterInitialise: 0.118 seconds, 2.69 MB
Application afterRoute: 0.119 seconds, 2.74 MB
Application afterDispatch: 0.457 seconds, 11.00 MB
Application afterRender: 0.575 seconds, 11.69 MB
Occupation mémoire
12369736
6 requêtes envoyées
1.
SELECT *
FROM jos_session
WHERE session_id = '48f16325781ac0218dda7a0694550f40'
2.
DELETE
FROM jos_session
WHERE ( time < '1280452287' )
3.
SELECT *
FROM jos_session
4.
UPDATE `jos_session`
SET `time`='1280459487',`userid`='62',`usertype`='Super Administrator',`username`='Thomas',`gid`='25',`guest`='0',`client_id`='1',`data`='__default|a:8:{s:15:\"session.counter\";i:769;s:19:\"session.timer.start\";i:1280436404;s:18:\"session.timer.last\";i:1280459475;s:17:\"session.timer.now\";i:1280459480;s:22:\"session.client.browser\";s:85:\"Mozilla/5.0 (Windows; U; Windows NT 6.1; fr; rv:1.9.2. Gecko/20100722 Firefox/3.6.8\";s:8:\"registry\";O:9:\"JRegistry\":{s:17:\"_defaultNameSpace\";s:7:\"session\";s:9:\"_registry\";a:9:{s:7:\"session\";a:1:{s:4:\"data\";O:8:\"stdClass\":11:{s:23:\"com_modulesfilter_order\";s:10:\"m.position\";s:27:\"com_modulesfilter_order_Dir\";s:0:\"\";s:23:\"com_modulesfilter_state\";s:0:\"\";s:26:\"com_modulesfilter_position\";s:1:\"0\";s:22:\"com_modulesfilter_type\";s:1:\"0\";s:26:\"com_modulesfilter_assigned\";s:1:\"0\";s:17:\"com_modulessearch\";s:0:\"\";s:21:\"searchcom_comprofiler\";s:0:\"\";s:29:\"viewcom_comprofilerlimitstart\";i:0;s:29:\"viewcom_comprofilerlastCBlist\";s:11:\"showplugins\";s:26:\"filter_typecom_comprofiler\";s:1:\"0\";}}s:11:\"application\";a:1:{s:4:\"data\";O:8:\"stdClass\":1:{s:4:\"lang\";s:0:\"\";}}s:6:\"global\";a:1:{s:4:\"data\";O:8:\"stdClass\":1:{s:4:\"list\";O:8:\"stdClass\":1:{s:5:\"limit\";s:3:\"100\";}}}s:11:\"com_modules\";a:1:{s:4:\"data\";O:8:\"stdClass\":1:{s:10:\"limitstart\";i:0;}}s:13:\"com_installer\";a:1:{s:4:\"data\";O:8:\"stdClass\":{s:10:\"limitstart\";O:8:\"stdClass\":4:{s:6:\"module\";i:0;s:6:\"plugin\";i:0;s:8:\"template\";i:0;s:9:\"component\";i:0;}s:7:\"modules\";O:8:\"stdClass\":1:{s:6:\"client\";s:2:\"-1\";}s:7:\"plugins\";O:8:\"stdClass\":1:{s:5:\"group\";s:0:\"\";}}}s:11:\"com_plugins\";a:1:{s:4:\"data\";O:8:\"stdClass\":2:{s:4:\"site\";O:8:\"stdClass\":5:{s:12:\"filter_order\";s:8:\"p.folder\";s:16:\"filter_order_Dir\";s:0:\"\";s:12:\"filter_state\";s:0:\"\";s:11:\"filter_type\";s:1:\"1\";s:6:\"search\";s:0:\"\";}s:10:\"limitstart\";i:0;}}s:9:\"com_cache\";a:1:{s:4:\"data\";O:8:\"stdClass\":1:{s:10:\"limitstart\";s:1:\"0\";}}s:9:\"com_menus\";a:1:{s:4:\"data\";O:8:\"stdClass\":1:{s:8:\"menutype\";s:8:\"mainmenu\";}}s:10:\"com_kunena\";a:1:{s:4:\"data\";O:8:\"stdClass\":1:{s:7:\"install\";O:8:\"stdClass\":{s:4:\"step\";i:0;s:6:\"status\";a:7:{i:0;a:4:{s:4:\"step\";i:1;s:4:\"task\";s:30:\"Préparation de l\'installation\";s:7:\"success\";b:1;s:3:\"msg\";s:0:\"\";}i:1;a:4:{s:4:\"step\";i:2;s:4:\"task\";s:24:\"Décompression admin.zip\";s:7:\"success\";b:1;s:3:\"msg\";s:0:\"\";}i:2;a:4:{s:4:\"step\";i:2;s:4:\"task\";s:23:\"Décompression site.zip\";s:7:\"success\";b:1;s:3:\"msg\";s:0:\"\";}i:3;a:4:{s:4:\"step\";i:2;s:4:\"task\";s:24:\"Décompression media.zip\";s:7:\"success\";b:1;s:3:\"msg\";s:0:\"\";}i:4;a:4:{s:4:\"step\";i:3;s:4:\"task\";s:33:\"Activation du Plugin Mootools 1.2\";s:7:\"success\";b:1;s:3:\"msg\";s:0:\"\";}i:5;a:4:{s:4:\"step\";i:4;s:4:\"task\";s:22:\"Include sampledata.php\";s:7:\"success\";b:1;s:3:\"msg\";s:0:\"\";}i:6;a:4:{s:4:\"step\";i:5;s:4:\"task\";s:37:\"Installation réalisée avec succés!\";s:7:\"success\";b:1;s:3:\"msg\";s:0:\"\";}}s:4:\"task\";i:0;}}}}s:7:\"_errors\";a:0:{}}s:4:\"user\";O:5:\"JUser\":19:{s:2:\"id\";s:2:\"62\";s:4:\"name\";s:6:\"Thomas\";s:8:\"username\";s:6:\"Thomas\";s:5:\"email\";s:29:\"***@***.fr\";s:8:\"password\";s:65:\"***:***\";s:14:\"password_clear\";s:0:\"\";s:8:\"usertype\";s:19:\"Super Administrator\";s:5:\"block\";s:1:\"0\";s:9:\"sendEmail\";s:1:\"1\";s:3:\"gid\";s:2:\"25\";s:12:\"registerDate\";s:19:\"2005-03-29 23:25:00\";s:13:\"lastvisitDate\";s:19:\"2010-07-29 20:46:56\";s:10:\"activation\";s:0:\"\";s:6:\"params\";s:56:\"admin_language=\nlanguage=\neditor=\nhelpsite=\ntimezone=1\n\n\";s:3:\"aid\";i:2;s:5:\"guest\";i:0;s:7:\"_params\";O:10:\"JParameter\":7:{s:4:\"_raw\";s:0:\"\";s:4:\"_xml\";N;s:9:\"_elements\";a:0:{}s:12:\"_elementPath\";a:1:{i:0;s:58:\"/htdocs/public/www/libraries/joomla/html/parameter/element\";}s:17:\"_defaultNameSpace\";s:8:\"_default\";s:9:\"_registry\";a:1:{s:8:\"_default\";a:1:{s:4:\"data\";O:8:\"stdClass\":5:{s:14:\"admin_language\";s:0:\"\";s:8:\"language\";s:0:\"\";s:6:\"editor\";s:0:\"\";s:8:\"helpsite\";s:0:\"\";s:8:\"timezone\";s:1:\"1\";}}}s:7:\"_errors\";a:0:{}}s:9:\"_errorMsg\";N;s:7:\"_errors\";a:0:{}}s:13:\"session.token\";s:32:\"ab98adf8f246266366bdc5f23f5427a2\";}'
WHERE session_id='48f16325781ac0218dda7a0694550f40'
5.
SELECT *
FROM jos_components
WHERE parent = 0
6.
SELECT folder AS type, element AS name, params
FROM jos_plugins
WHERE published >= 1
AND access <= 2
ORDER BY ordering
Fichiers langue chargés
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.plg_system_debug.ini 1
* /htdocs/public/www/language/fr-FR/fr-FR.com_jcomments.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_kunena.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_kunena.ini
* /htdocs/public/www/components/com_kunena/language/fr-FR/fr-FR.com_kunena.ini 1
* /htdocs/public/www/administrator/components/com_kunena/language/fr-FR/fr-FR.com_kunena.ini 1
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_kunena.install.ini 1
* /htdocs/public/www/administrator/components/com_kunena/language/en-GB/en-GB.com_kunena.install.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_kunena.install.ini 1
* /htdocs/public/www/administrator/components/com_kunena/language/fr-FR/fr-FR.com_kunena.install.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.tpl_khepri.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.mod_submenu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_kunena.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_kunena.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.mod_title.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.mod_toolbar.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.mod_menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_groupjive.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_groupjive.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_communicator.menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_comprofiler.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_comprofiler.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_adsmanager.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_adsmanager.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_contact.menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_eventlist.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_eventlist.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_eweather.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_eweather.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_jcomments.menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_poll.menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_search.menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_shoutbox.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_shoutbox.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_uddeim.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_uddeim.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_xmap.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_xmap.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_zoo.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_zoo.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_banners.menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_newsfeeds.menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_weblinks.menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.mod_cb_adminnav.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.mod_cb_adminnav.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.mod_status.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.plg_system_jvc.ini 1
Diagnostic des phrases non traduites
Aucun
Phrase non traduite
Aucun
I don't know how to access the apache error log...
I'll ask my host tomorrow on how to access the apache error log... i'm tired... It's 05:20am in France !!!
One issue: I've lost the Kunena horizontal menu bar. Regenerating by clicking on "Create menu" button now adds "Forum" as the first item on my site's main menu, where it is not supposed to be. If I click on the new "Forum" entry, it brings me to my Kunena forum, but the Kunena horizontal menu still isn't appearing.
Any ideas what might be going wrong here?
Thanks again.
-Colin
cbrace wrote:
Where would you like the "Forum" link to be? :dry:I've lost the Kunena horizontal menu bar. Regenerating by clicking on "Create menu" button now adds "Forum" as the first item on my site's main menu, where it is not supposed to be.
After upgrading to 1.6 my forum has no topmenu...?
I found out that it is now a separate module and menu in Joomla (how clever - good idea!!) - but even though everything seems to be enabled, I have no topmenu...
Any idea what I'm missing...?
Rie
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 10M
board_title efter5 forum board_offline 0 board_ofset 0 offline_message <h2>Forummet er i øjeblikket ved at blive opdateret.</h2>
<div>Prøv igen om lidt.</div>enablerss 0 enablepdf 1 threads_per_page 20 messages_per_page 6 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 0 template default showannouncement 0 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 50 maxsig 300 regonly 0 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 imageprocessor gd2 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 150 allowfileupload 0 allowfileregupload 1 filetypes zip,txt,doc,gz,tgz filesize 120 showranking 1 rankimages 1 avatar_src fb_profile pm_component userlist_rows 30 userlist_online 0 userlist_avatar 1 userlist_name 0 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 0 latestcategory showstats 1 showwhoisonline 0 showgenstats 1 showpopuserstats 1 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 rules_infb 1 rules_cid 1 rules_link www.kunena.com/ help_infb 1 help_cid 1 help_link www.kunena.com/ showspoilertag 1 showvideotag 1 showebaytag 1 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage categories default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 0 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access jomsocial integration_login jomsocial integration_avatar jomsocial integration_profile jomsocial integration_private jomsocial integration_activity jomsocial boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 1.8.10) | UddeIm: Disabled or not installed
Can you post a screen shot of how your Forum menu entry has been setup?
If possible you would want it as a Menu Alias to the Kunena Menu.
Sorry for going offtopic, thanks to Sozzle for splitting the thread, which I have only seen just now.
At the moment, my Kunena menu is acting weird.
When one clicks on ../forum, the menu isn't visible, nor does it appear when browsing the category index.
Only after clicking on my profile does it suddenly appear, and then it remains visible.
I'd be happy to post a screen shot, but I am not sure what you mean by "forum menu entry".
Thanks.
