Question Joomla Module in Post
11 years 4 months ago #1
by GDSLang
Joomla Module in Post was created by GDSLang
i'm using Joomla 2.5.26 and Kunena 1.6.2.
My problem might be very simple to solve but i can't find an answer for it. :dry:
Is it possible to show a joomla module in a single kunena post similar like it can be done in a joomla article? If it is can someone tell me how?
thanks
GDSLang
thanks
GDSLang
11 years 4 months ago #2
by anne785
Replied by anne785 on topic Joomla Module in Post
ya it can be done using the respective tool.
11 years 4 months ago #3
by GDSLang
Replied by GDSLang on topic Joomla Module in Post
Thanks for the quick answer,
but which tool do you mean?
I want following scenario:
If I answer a topic, it should be possible that I contain a module i.e. with a token like [MODULEPOSITION]
Do you know what I mean?
thanks
GDSLang
thanks
GDSLang
11 years 4 months ago #4
by skybax
Replied by skybax on topic Joomla Module in Post
You can use kunena_msg_1 position and this will add the module under the first post and you wont need to use any tools that can brake your site.
And also i recommend updating to Kunena 2.0.3. your veresion of kunena is not supported anymore.
11 years 4 months ago #5
Replied by sozzled on topic Joomla Module in Post
We do not discuss unsupported versions of Kunena on this forum. This topic concerns K 1.6.2 and was posted in the K 2.0 section of the forum. I have moved this topic to its correct category.
Time to create page: 0.497 seconds
