Question RSS and Avatar Problems
13 years 2 months ago - 13 years 2 months ago #1 by Zero9195
Hello again,
I have some Problems when trying to get the RSS Feeds working. I activated the feature and I had one feed from beginning. But after I deleted it, and wrote some more Threads, noone is listed in the feeds. You can take a look into that here moonsblade.com/joomla/index.php/forumsdasd in the bottom right corner is the Feed-Button. I wrote around 5-6 threads.
EDIT: It seems the problem appears, because the access is for "Nobody" instead "Everyone" when I choose "Public", but don't know why and where I ca change it.
Another Problem is, that after activating Avatars, I can upload it, see it in the Profil and everywhere else, except in the "Last Post" and on the top of the page next to the Username. I activated the Option "Show avatar on Index view, Recent Topics and My Topics?". Maybe any sollution?
EDIT: I can't see the Avatars in the Backend too, there are jut some red X.
Here is a configuration Report:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : moonsblade | author: | version: 1.0 | creationdate: 2011-02-18
Thanks for Helping,
Zero9195
Last edit: 13 years 2 months ago by Zero9195.
13 years 2 months ago #2 by xillibit
We have seen plenty of issues recently about rss feed....
For avatars, you need to have gd library installed/enabled on your system, talk to your host about it.
13 years 2 months ago - 13 years 2 months ago #3 by Zero9195
Ok thanks, but I have problems installing it. I'm using Ubuntu, and is I type "./configure" it says everytime "Perimssion denied", even if I'm using root and chmod 755. You know a solution?
EDIT: It works now, "configure" wasn't exeutable ;)
Time to create page: 0.480 seconds
