Merged How to implement Search Engine Optimisation - SEO - in Joomla
- stevetyler
I already have existing categories, topics and threads on the site, does this mean that all these need to have new SEO-friendly links put in? I assumed the site would sort it all out itself?
sozzled wrote: If you are getting "page not found" errors, it's because your menu items are wrong (or broken). That's a different topic. Please read the FAQs (see the menu tab on this page) and particularly the part about how to fix Kunena menu problems.
- lepermessiah
- Thank you received: 1
only problem is URL rewriting. on clean install of Kunena in clean Joomla, links are complete. I mean that if you are in site/Main/Category1/Subcategory1/topic#post you see it in URL. In my non-dev Kunena I see only site/subcategory/topic#post
settings are the same, but it doesn't work same.
any advice? thank you
(1) Enable Search Engine Optimisation (SEO)
(2) Every Joomla component must have a menu item. These menu items don't have to be visibly displayed on your site, but they must exist and they must be published!
If you don't have a Joomla menu item, you won't get SEF URLs. If you don't setup Joomla SEO properly, you won't get SEF URLs. Make sure that you don't have any old menu items lurking in the menu trash. This is not a Kunena thing; this is a Joomla thing.
- lepermessiah
- lepermessiah
- hellilyntax
- Junior Member
Im having problem with Kunena Search & Preview Pane when enabling Joomla SEF.
It turn my keyword to '/forum/advsearch.html?q=mykeyword' in input box.
And preview pane has no reaction(blank).
- hellilyntax
- Junior Member
i've tested same site on local wamp server, same site, works just fine....
hmmm...i'll get back soon for the result.
