Question Multilingual LTR and RTL sites. Load different kunena.forum.css files for each language
13 years 10 months ago - 13 years 8 months ago #1 by hopewise
hello,
it will be great if the admin can determine a different css file per language,
for ex:
kunena.forum_en.css for englsih
kunena.forum_ar.css for arabic
instead of hard coding the css file name to always be kunena.forum.css
this will be a great feature for languages that are right to left, and will increase Kunena penetration into more communities.
how can i do that trick ?
thanks,
hopewise
Last edit: 13 years 8 months ago by sozzled. Reason: Changed subject to improve search relevance
13 years 10 months ago #2 by @quila
Replied by @quila on topic Re: kunena.forum.css ?
how you think to load this diferent files?
With option in the configuration or..??
13 years 10 months ago #3 by hopewise
Replied by hopewise on topic Re: kunena.forum.css ?
i shall load the css depending on the selected language at JoomFish,
but, where to tell Kunena about the desired css file ??
13 years 8 months ago - 13 years 8 months ago #4 by OfekA
Replied by OfekA on topic Re: kunena.forum.css ?
Anything new with topic? I really need this feature.
If someone can try and guide me which files i need to edit I'd be so greatful!
I have a multilingual website with English and Hebrew, and I can't seem to find any solution for the css.
Thanks in advance..!
Last edit: 13 years 8 months ago by OfekA.
13 years 8 months ago - 13 years 8 months ago #5 by OfekA
Maybe if I'll try something like this, will it work?
kunena.php lines 267-275 original:
if ($fbConfig->joomlastyle < 1) { if (file_exists(KUNENA_JTEMPLATEPATH.'/css/kunena.forum.css')) { $document->addStyleSheet(KUNENA_JTEMPLATEURL . '/css/kunena.forum.css'); } else { $document->addStyleSheet(KUNENA_TMPLTCSSURL); }
I changed it to this:
if ($fbConfig->joomlastyle < 1) { if ($this->language=he-IL) { $document->addStyleSheet(KUNENA_JTEMPLATEURL . '/css/he-il.css'); } else { $document->addStyleSheet(KUNENA_JTEMPLATEURL . '/css/en-gb.css'); }
13 years 8 months ago #6 by Matias
Replied by Matias on topic Re: kunena.forum.css ?
Kunena 1.6 supports this in the templates.
You just need to add above if's to the initialize.php in your template.
BTW: always quote strings in PHP: "he-IL" or 'he-IL'. Otherwise your error log will grow fast.
The following user(s) said Thank You: OfekA
13 years 8 months ago - 13 years 8 months ago #7 by OfekA
Matias wrote: Kunena 1.6 supports this in the templates.
Thank you so much, the quote strings made the code work, and now it uses the "he-il.css" file, but for both languages.. it doesn't use the "en-gb.css" for english for some reason.
I tried looking for a initialize.php but there is no such file in my components\com_kunena folder.
Any suggestions?
13 years 8 months ago #8 by Matias
Try this:
if ($this->language=='he-IL')
13 years 8 months ago - 13 years 8 months ago #9 by OfekA
Matias wrote: Try this:
Now it uses for both English and Hebrew the "en-gb.css" file. Any idea what's wrong?
Edit: I also know that it's the "en-gb.css" because i made a special tweak for it so i'll notice, so just to clarify, it's not loading the "kunena.forum.css".
13 years 8 months ago - 13 years 8 months ago #10 by OfekA
So basically, this is the current code on kunena.php line 267:
if ($fbConfig->joomlastyle < 1) { if ($this->language=='he-IL') { $document->addStyleSheet(KUNENA_DIRECTURL . '/template/default_ex/he-il.css'); } else { $document->addStyleSheet(KUNENA_DIRECTURL . '/template/default_ex/en-gb.css'); }
With this code (I double checked) the kunena system loads the file "en-gb.css" on both Hebrew and English.
As far as I understand, this can only mean, that this line is somewhat corrupted:
I presume that's it's incorrect, but i'm not sure to what i can change it..
Any suggestions?
Time to create page: 0.579 seconds
