- Thank you received: 1
Question Trying to install Kunena - having problems with directory permissions
-1 - An error has occurred.
Unable to create target folder
Call stack
# Function Location
1 JAdministrator->dispatch() /user/homepages/virtual/eacentral/eabytes/administrator/index.php:67
2 JComponentHelper->renderComponent() /user/homepages/virtual/eacentral/eabytes/administrator/includes/application.php:136
3 require_once() /user/homepages/virtual/eacentral/eabytes/libraries/joomla/application/component/helper.php:162
4 JController->execute() /user/homepages/virtual/eacentral/eabytes/administrator/components/com_installer/admin.installer.php:44
5 InstallerController->doInstall() /user/homepages/virtual/eacentral/eabytes/libraries/joomla/application/component/controller.php:236
6 InstallerModelInstall->install() /user/homepages/virtual/eacentral/eabytes/administrator/components/com_installer/controller.php:71
7 JInstaller->install() /user/homepages/virtual/eacentral/eabytes/administrator/components/com_installer/models/install.php:86
8 JInstallerComponent->install() /user/homepages/virtual/eacentral/eabytes/libraries/joomla/installer/installer.php:332
9 com_install() /user/homepages/virtual/eacentral/eabytes/libraries/joomla/installer/adapters/component.php:293
10 JFolder::copy() /user/homepages/virtual/eacentral/eabytes/administrator/components/com_kunena/install/kunena.install.php:149
11 JError::raiseError() /user/homepages/virtual/eacentral/eabytes/libraries/joomla/filesystem/folder.php:64
12 JError::raise() /user/homepages/virtual/eacentral/eabytes/libraries/joomla/error/error.php:171
13 JException->__construct() /user/homepages/virtual/eacentral/eabytes/libraries/joomla/error/error.php:136
When Debug in joomla is off I only get the
Now heres the kicker when I give all folders full write access it will install just fine witch makes me think that it is a permssion prob but I really don't want to have my site open to everyone that will leave the server open to hackeking so what do I do to fix this?
thanks
tbarlow
This issue isn't related to security...
I have modified a bit Kunena 1.5.9, i hope that will solve your issue :
xillibit.perso.sfr.fr/ftp/com_kunena_v1....-21-with_fix.tar.bz2
Tell me if this has worked after an new installation
- RedElectro
Uploading to Joomla, I got another error saying "Unable to write entry" and then this...
Warning: file_put_contents(/tmp/install_4b8c1cc774255/:K�]�]u��nZ���Ρ���J�����=��d�����w���$��?����K ݄�����hh�t��]d�4�~�cRO(妍) [function.file-put-contents]: failed to open stream: Is a directory in /****/*****/public_html/libraries/joomla/filesystem/file.php on line 298
Completely out of my depth! While I think the Kunena forum is fantastic, is there not a way of making the installation easier? I don't have these problems with anything else.
I understand that you are trying to install Kunena when you encounter these problems.
What are the directory and file permissions on your website?
What version of Kunena are you trying to install? Which installation kit are you using?
What version of Joomla are you running?
What version of PHP are you using?
What kind of webserver is involved and what kind of database system is being used?
- RedElectro
I have gone through each relevant directory/sub directory and set the Perms to 777
I am trying to install Kunena 1.5.9 and I currently have 1.5.6 installed.
I am running Joomla 1.5.15
Apache version 2.2.14
PHP version 5.2.11
MySQL version 5.0.89-community
Hope this helps?
Thanks in advance
Red.
I noticed, from an earlier message, you said something about a .TAR file. Are you trying to install Kunena 1.5.9 from a .TAR file? Have you tried to use the .ZIP installation kit instead (this is a long-shot, I know, but I've heard other people have had problems installing with a .TAR archive)? Let's at least eliminate this possibility.
- RedElectro
I have set the permissions in the components/com_kunena and administrator/com_kunena to 777 almost every file and every folder and I'm still not having any success.
It's got me completely puzzled.
