- Thank you received: 2
Question 1.5.14 upgrade issue
The result is "Upgrading Kunena to version 1.5.14 has failed!" at the top when I go to the component control panel, and "Installed version: Kunena 1.5.14 | 2010-11-04 | 1902 [ NOT UPGRADED ]..." at the bottom.
"XML error on 3:84" and "Installed version: Kunena 1.5.14 | 2010-11-04 | 1902 [ NOT UPGRADED ]..." at the bottom.
What can i do please? I can't use 1.6 because my editor is not showing in 1.6.
Please help !!
Try this:
manifest.xml line 5
Regards 810
PHP Built on: Linux xyz 2.6.32-22-server #36-Ubuntu SMP Thu Jun 3 20:38:33 UTC 2010 x86_64
Database Version: 5.0.51a-3ubuntu5.4
Database Collation: utf8_general_ci
PHP Version: 5.2.4-2ubuntu5.7
Web Server: Apache
Web Server to PHP interface: apache2handler
Joomla! Version: Joomla! 1.5.22 Stable [ senu takaa ama woi ] 04-November-2010 18:00 GMT
@810
Thanks, I figured already it's a name conflict. But then what? Try upgrade again? Uninstall/reinstall? Will it mess up my setup? I'd rather wait for an official and tested fix.
1) Edit the manifest.xml in the package
2) Run update again, then the problem is gone.
Hellokmilos wrote: Thanks, I figured already it's a name conflict. But then what? Try upgrade again? Uninstall/reinstall? Will it mess up my setup? I'd rather wait for an official and tested fix.
Now, upgrading is OK for me with these modifications :
In file named manifest.xml :
Line 5, replace
In file named kunena.install.upgrade.xml :
Line 3 and line 348, replace
Yep, editing only manifest.xml is not enough (at least not after the build is done.)
For a long term solution maybe adding
to the /trunk/1.5/administrator/components/com_kunena/install/kunena.install.upgrade.xml template would be best?
- treehugger
- Thank you received: 1
joomlacode.org/gf/project/kunena/tracker...racker_item_id=24742
