Kunena 6.2.6 released
This is not a support forum for Community Builder or its related products. For Community Builder support you should visit Joomlapolis .
The information given in this category is intended to guide users who want to use Community Builder with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of Community Builder.
Question Problem Integration Kunena 5.0.1 and CB 2.0.14
7 years 7 months ago #1 by druskus
Hi to all i have my installation Joomla 3.6.2 Kunena 5.0.1 and CB 2.0.14 i have migrated kunena to 4.0.11 a 5.0.1 the problem is in profile avatar and plugin is regular configured but if click nickname and topic the link of avatar go in home page and not in profile CB Url same problem with cb activity but this report in CB Forum.
7 years 7 months ago #2 by 810
7 years 7 months ago #3 by druskus
Thank you for reply, ok in this mode i have solved problem avatar, but i have problem to see kunena post in cb activity, i have open new post in cb forums
In attachment for all, user.php with your modify
File Attachment:
File Name: user.zip
File Size:9 KB
7 years 7 months ago #4 by 810
do you have a link, to that activity so I can see the bad url
The following user(s) said Thank You: druskus
7 years 7 months ago #5 by druskus
7 years 7 months ago #6 by 810
could you add the kunena report
7 years 7 months ago #7 by druskus
is a kunena problem not of CB?
7 years 7 months ago #8 by 810
the url is ok, but not translated. so there is somewhere a issue.
I need to see the kunena settings from you:
Backend - kunena - tools - report
7 years 7 months ago - 7 years 7 months ago #9 by druskus
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 20000M
Joomla default template details : jf_connecto | author: JoomForest.com | version: 1.3 | creationdate: 05.05.16
Kunena default template details : Crypsis | author: Kunena Team | version: 5.0.1 | creationdate: 2016-08-20
Kunena version detailed: Kunena 5.0.1 | 2016-08-20 [ Binturong ]
Third-party components: AltaUserPoints 1.1.4 | CommunityBuilder 2.0.14+build.2016.07.09.00.27.18.f7e840c79 | UddeIM 3.9
Plugins: Search - Kunena Search 5.0.0 | Content - Kunena Discuss 5.0.0
Modules: Kunena Latest 5.0.0 | Kunena Stats 5.0.0 | Kunena Search 5.0.0
Last edit: 7 years 7 months ago by druskus.
7 years 7 months ago #10 by 810
the settings are ok, then I need to look later, if I have the same issues.
Time to create page: 0.460 seconds
