This is not a support forum for Community Builder or its related products. For Community Builder support you should visit Joomlapolis .
The information given in this category is intended to guide users who want to use Community Builder with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of Community Builder.
Question Post ordering and signature edit
9 years 3 months ago #1 by sitnud
Hi all,
I am running cb 2.0.4 and Kunena 3.0.6
I need my users to be able to change their message ordering and signature from their CB profile. I can find where I assign the fields in the forums plugin but have no idea how to build those 2 fields so they work. The tutorial only shows how to select one that is there from default and there are no guides that I can find. The old guides do not work. Can someone please help me out here? I really don't want to disable the CB profile inside kunena.
I have the kunena and cb plugins both enabled and the cb profile enabled within kunena.
9 years 3 months ago #2 by sitnud
and zero response on the cb forum in over 4 days...
9 years 3 months ago #3 by 810
please add the kunena report here.
9 years 3 months ago #4 by sitnud
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 50M | Max file upload: 16M
Joomla default template details : warehouse | author: Robin Jungermann - Crosstec GmbH & Co. KG | version: 1.1 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Third-party components: CommunityBuilder 2.0.4 | UddeIM 3.5
Plugins: None
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1
9 years 3 months ago #5 by 810
go to backend - kunena - plugins - select Kunena. disable avatar and profile.
You should also check the cb setting. id forum plugin is enabled.
Check also: www.joomlapolis.com/forum/153-profession...nd-signatures#188644
9 years 3 months ago #6 by sitnud
OK,
I got the signature working now. How do I build the field for changing the post order so they can each set it the way they like it?
9 years 3 months ago - 9 years 3 months ago #7 by 810
go to the plugin on cb. select cb forums - paramaters - select model "kunena 3.x" - there you see options then. change the ordering to "view"
Last edit: 9 years 3 months ago by 810.
9 years 3 months ago #8 by sitnud
It wants me to pick a CB field which doesn't exist and the old parameters I found in the archives don't seem to work.
9 years 3 months ago #9 by 810
can you make a screenshot
9 years 3 months ago #10 by sitnud
these are the options in the drop down. These are the fields under cb->fields. All of the drop downs give the same field choices. I had to create the signature field but that was pretty simple.
[IMG
Time to create page: 0.611 seconds
