Question [Readme] How to translate and update my language into Kunena distribution
Each registered user have write access on the wiki, so if you have an idea to make it better just edit it.
When you create a new translation or update your existing, please send an email to translations at kunena dot com
This would save a lot of time searching through the forum after it
Thank you
Kunena Contributor & Language Coordinator
Kunena Birthday Module | Kunena LaTeX Plugin | SchuWeb Sitemap with free Kunena Plugin
Always up to date with Twitter
Please read the documentation under:
docs.kunena.org/index.php/Translating_Kunena and docs.kunena.org/index.php/Transifex
Transifex Team told me that the bug that sometime labels get translated will be fixed on Tuesday!
I also added the com_kunenaimporter translation file to transifex.
So happy translating in a new and easy way!
I will keep you updated about what will happen.
But you will be save with using <br /> in all other files.
So you can use again \n in your translations!
If you have any problems with transifex, use the feedback function of transifex or discuss the issue with me.
Thank you!
Taking everything else into consideration, the project is placed in the uneviable situation of either releasing K 1.6.5 with only English language support "guaranteed" or waiting until the Transifex team makes good on fixing the translation tool. Given the pressure on the project to release Kunena in a form that interoperates with J! 1.7.0 this reduces our options.
The current plan is to release K 1.6.5 with the following advisories:
(1) Only with English language support; translators will need to spend time - probably an hour - to check those untranslated strings and to provide suitable language packs for those people who need them.
(2) Other language translations to be made by the translators as soon as practicable after the release of K 1.6.5 and posted on the forum.
(3) A further release (K 1.6.6) will be offered when all language translations have been updated.
The recent announcement by the Joomla development team, and the release of J! 1.6.6 will also help a lot of people who are fearful of the XSS security vulnerability found in earlier releases of J! 1.6 and who feel compelled to upgrade to J! 1.7.0 whether or not this causes other issues.
This also gives us some "breathing space" to work steadily on resolving the translation issues that you have discovered.
So modules/plugins could contain still bugs which need to be fixed ...
PLS control your translations and keep them up to date!
svanschu wrote: So modules/plugins could contain still bugs which need to be fixed ...
nb-NO is marked 100% - how do we know if there is any Transifex-bugs in them?
Also \n got translated on export into real linebreaks which would break compatibility with J15
And Keys where translated on export COM_KUNENA_"OK"=""OK""
That where the main bugs.
Here is a list of my reports getsatisfaction.com/people/svanschu
